ki-gass
When you have a very technical issue, let's try to ask John who is a real expert since he has spent more than 20 years of his life working on TE 20s !
In english here please
Modérateur: VINCENT
ki-gass
Message par webmaster » 16 Mai 2007, 21:19
Hi John
What is the exact meaning of Ki-Gass ? A brand ? Kickoff gas ? What else ? :wink:
Message(s) : 1358208
Message par john » 07 Juin 2007, 14:59
Sorry JC, I completely missed this question. Ki-gass is for easy starting as you know and it was fitted originally to some light aircraft engines and still is today. "Ki-Gass" was a fluid that ignited easily for cold starts although Ferguson never said use that, only to use diesel in the Ki-Gass system which would be safer and it will ignite if the Heater works, so the end result is the same. The original TEF 20c engine didn't have any Ki-gass equipment and I suppose when it was on test in various parts of the world they found that it didn't always start like it should. The first engines used a blow lamp into the inlet manifold if it was really cold, this was done through a large blanking plug, of course this isn't really practical and could be dangerous, so they had to find something that was safer which 60 years ago wasn't easy. The TEF is a reasonably good starting engine and just using the cold start button is usually enough, when it does get colder use the heater and if it gets really cold then use the Ki-gass, you shouldn't need to use it each day, very rarely in fact....John
john
THE Ferguson Expert ;-)
Message(s) : 120
Message par Raph » 08 Juin 2007, 07:27
Thanks for the story John
Et Danny, tu dors ! :lol:
If it cames from aircraft engines you should have known this Danny !
I know your "bus" doesn't use diesel but you are the one here from "the world of lightness"! :lol:
Raph
L'autre Harry.....
Message(s) : 419
Message par dannyleloup » 09 Juin 2007, 11:09
:oops: :oops: I'm not used in using light arcraft engines..... I only know P(ost)C(ombustion)-GAS system. :lol: :lol: :lol:
dannyleloup
Ferguson SouthPark
Message(s) : 1361
Message par cattiaux jp » 09 Juin 2007, 19:58
merci pour l anglais :shock: j aurais du ecoute a l ecole :lol: :wink:
Message par webmaster » 10 Juin 2007, 21:24
C'est la rubrique de John, IN ENGLISH ! :wink: :wink:
Retour vers Contact THE expert
